WDC SMR PBA Access [ Why Not Working ]
Postby Amarbir[CDR-Labs] » 09.10.22, 02:12
My Friends ,
I wanted to give you a scenario ,i am unable to recover any data using PC3k 7.0.32
1 : Charger HDD 2TB Formatted
2 : ROM Removed ,Read Using External Programmer + Saved in .BIN Format
3 : .BIN File Programmed Into SATA Unlocked Board
4 : Reading MBR Resulted in Encryption , Using Decryption option also Its Encrypted
5 : Me Assuming Keys are in MCU of Original USB Board
6 : No Point in Using PBA Accesss
7 : ROM Code That was Read Was Send To My Student With Version 7.1 PC3K utility
8 : I received Unlocked Code , Code Programmed In ROM chip And Soldered Into USB PCB
9 : 4 Capacitors Removed From USB Board And Converted To SATA
10 : Full SA Access And Sector Access To MBR indeed Gave MBR Code
11 : Me Assuming due to native CPU encryption is defeated
12 : I tried PBA access and still i cannot find any Video ,Photos
13 : What the is going on .....
Re: WDC SMR PBA Access [ Why Not Working ]
Postby Amarbir[CDR-Labs] » 11.10.22, 13:53
Acelab,
Can Someone Please Comment .....
igen
Postby igen » 23.04.24, 09:31
Hello Amarbir,
Do you already know what caused this problem?
I have an identical problem...
WD40NDZW (SpyGlass2) disk after formatting the partition.
I have the original PCB converted from USB to SATA.
New-empty partition visible (via SATA).
Without the second translator, it finds no signatures.
Since it is SpyGlass2 Ultra (encrypt by MCU), the data are encrypted using T2.
So PBA mode is out of the question - just try LBA.
Does anyone have an idea how to get to the data after formatting?
Thank you in advance for any information.
Also from anyone who has encountered such a problem.
Igen
P.S.
I've noticed that often someone needs SA sources for SpyGlass2.
I uploaded it to hddguru
Link: https://files.hddguru.com/download/PC-3 ... 19UZVT.ZIP
WD40NDZW-11A8JS0 - 01.01A01
ROM version: 00.0AA
ROM F/W version: 0000000A
Overlay: 00.0BA
Servo: 03.7B
Marcus Tullius Cicero
