Several Patriots with huge ECC errors
jojo2012
Postby jojo2012 » 29.09.22, 15:31
as subject I am getting a lot of Patriots (PS3111) where most of the blocks have ECC errors.
Even the last case I'm handling to give you an example out of 800MB, 600MB have ECC errors.
Is there anything that can be done or is the data in those blocks unrecoverable?
Jojo
Re: Several Patriots with huge ECC errors
Postby Roman_TS » 29.09.22, 20:20
Hello Jojo,
Usually, the heating/freezing helps to reduce the number of errors. The NAND quality isn't good in the latest models of the SSD, that's why after the first pass of copying, we have to reread the bad sectors again.
jojo2012
Postby jojo2012 » 29.09.22, 23:25
Roman_TS wrote:Source of the post Hello Jojo,
Thanks so much Roman, I'll try that
Return to “Other SSD”
