ST2000DM001 : Need help with translator issue
hddr49
Postby hddr49 » 24.06.22, 09:43
Hi there.
my pc3k support is going to be renew, but it takes time.
Meanwhile I need help with this case.
History :
Drive init ok
Busy at reading ID
alternative init failed by terminal
I have read ROM via termimnal and BOOT CODE, seems ok to me (comparaison made with a same model ROM)
When I try to init with ROM image, it hangs with a "table code segment is not found"
V1 slip G-LIST P-LIST are huge
V2 T-List has 2 entries by head
V40 empty
Head resistance seems ok
Can read and write System files via terminal (ie 93)
Clear SMART help me a bit.
Id can be read, all backups are good.
Start to img, but failed at 84000
Try to recover translator, but
Code: Select all
Start scanning...
"Fork" searching: 0 - 3907029167
Verify sectors ext error Device error detected "UNC"
Translation "fork" direction detection ambiguity!
Correct it manually!
LBA : 676216
I don't usually deal whith translator issues, most of my cases are head damaged.
Can you please help me ?
