hi
I did physical test and then add defect list into P list shows error overflow defect list
please guide me how to resolve it.
WD3200BEVT-11ZCT0
overflow defect list WD Topic is solved
Re: overflow defect list WD Topic is solved
you should resize p-list or moudle 33 size in bigger size
How should I do this?
Are the instructions explained somewhere?
Thank you for writing its URL.
roozbeh wrote:Source of the post you should resize p-list or moudle 33 size in bigger size
in work in service area you can resize module 33 and change the address
