PS5013-E13-35 [ Supported ]
Typical Flash recovery cases
Postby Amarbir[CDR-Labs] » 08.05.22, 15:11
Hello ,
There is a Prograde C Fast Card based on PS5013-E13-35 , It has two BGA-132 Chips ,Is this supported .
Re: PS5013-E13-35 [ Supported ]
Postby DataMedics » 08.05.22, 22:45
There's no reason it shouldn't be supported. C Fast is just SATA with a different connector. Every C Fast card I've ever gotten in just used the generic loader for the controller. I don't think they reprogram the FW like some laptop makers do.
Postby Roman_TS » 09.05.22, 10:14
Hello Amarbir.
PS5013 is supported in Portable III, there is a chance if you find a good adapter from CFast to NVMe M.2 it would be possible to recover this case. Need to check. Looks like this modification isn't a common SATA-based SSD, because PS5013 is NVMe PCIe controller.
