840 loader decryption issues?
headcrash
Postby headcrash » 05.04.22, 21:51
I have MZ7TD256HAFV (S4LN021X01-8030).
There are 4 loaders for this device, this device will only accept the last one on the list that says Logical Access - "Off" and Encryption - "Off".
I was able to create translator with the last loader on the menu and I got a 99% image but the data appears bad or encrypted.
I am unable to see any file system/structure in DE or other tools.
Am I unable to decrypt because the loaders with Encryption "On" do not work with this drive?
Thank you for your time.
Re: 840 loader decryption issues?
Postby digitalsupport » 06.04.22, 08:50
Think your drive belongs to generation 2 or 3 of these 840 EVO, Ace can only work with loader on generation 1
How does the drive ID in safe mode ? ROMMEX17 ?
Create a ts ticket to be sure.
Postby Roman_TS » 06.04.22, 11:32
headcrash wrote:Source of the post
Hello. Please make a ticket on ts.acelab.eu.com - we will guide you. There is an additional step that we need to do to see the data.
300ddr
Postby 300ddr » 06.04.22, 22:41
Hi Roman -- can you explain what this step is? I'm just curious.
Postby Roman_TS » 07.04.22, 09:13
There is an additional option to force decryption. Samsung drives starting from 8xx family are using a hardware encryption. Sometimes we have to set decryption manually in the Utility settings.
300ddr
Postby 300ddr » 07.04.22, 19:33
Thanks!
Continuum
Postby Continuum » 08.10.24, 06:01
Roman_TS wrote:There is an additional option to force decryption. Samsung drives starting from 8xx family are using a hardware encryption. Sometimes we have to set decryption manually in the Utility settings.
Can You explain this step by step? I have this issue as well.
Postby Roman_TS » 08.10.24, 16:48
Please make a ticket on ACELab TS portal. We will guide you.
Return to “840 Series”
