LENSE30256MSP34MEAT3TA
headcrash
Postby headcrash » 29.03.22, 18:49
I have 2 cases of LENSE30xxxMSP34MEAT3TA, where the firmware fix works with no errors, translator builds successfully but when imaging in DE, 99% of the sectors are read as "missed marker".
What does this mean?
Is this recoverable or fixable?
Thanks!
Re: LENSE30256MSP34MEAT3TA
Postby Roman_TS » 30.03.22, 09:27
Hello. You need to activate the Decryption of the data. Current NVMe drives based on 88SS1093 are using a TCG OPAL Encryption.
Exit from DE, return back to Marvell Utility and follow by: Tests -> Service Information -> TCG -> Load Configuration.
After that, make a new task in DE (chose PC-3000 Utility as a source) and data would be available. Step-by-step guide is right here:
https://youtu.be/47eXzxZk-0E?t=7191
headcrash
Postby headcrash » 04.04.22, 18:11
Thank you for the information, it worked one one of the two drives.
Postby Roman_TS » 05.04.22, 09:43
You can contact TS dpt and our engineers will help you with the second drive. Solution for 88SS1093 is pretty flexible and should work almost with all models of Lenovo/Ramaxel.
Return to “Marvell based NVMe drives”
