PCB 2060-810035 to SATA
andrew55
Postby andrew55 » 29.12.21, 07:14
Good morning !
Colleagues, tell me which point leads to which contact on the connector? I do not have enough intelligence. :-(
msurgeon
Re: PCB 2060-810035 to SATA
Postby msurgeon » 30.12.21, 01:48
810035 wiring.jpg (14.29 KiB) Viewed 28192 times
Substitute 2, 3, 5 and 6 on the 7-pin connector for 1,2 ,3, and 5 in picture.
andrew55
Postby andrew55 » 30.12.21, 13:47
Big thanks!
andrew55
Postby andrew55 » 09.01.22, 06:34
Friends!
I find com port points for this PCB. You have may be ?
Postby DataMedics » 11.01.22, 18:34
Com port should be the same as you see here: https://www.data-medics.com/forum/threa ... /post-7071
Hddex
Postby Hddex » 21.10.22, 22:25
I'm doing the same but is the power coming from the USB connector already on the PCB after soldering SATA connections to the PCB? If so how do you control it from the PC-3000 portable if it is going to be connected to a SATA connection and not from USB connection. Does it really matter if I use another source power? :shockable:
