ST8000AS0002 Cannot access user data, cannot enable tech mode
jpkpc3k
Postby jpkpc3k » 26.12.21, 15:26
Code: Select all
HDD family detecting...
Tech Key...
Error executing command  "En Tech" (ABR)
Family ID: 00
Unlocking Diag Mode (terminal)...
Error unlocking Diag Mode: Terminal : reply timeout error
Selected family......................... : 00, F3 Arch (common)
Model by ID............................. : ST8000AS0002
Tech Key...
Terminal : error detecting HDD terminal baud rate
Any ideas what could cause this problem?
Re: ST8000AS0002 Cannot access user data, cannot enable tech mode
Postby digitalsupport » 27.12.21, 11:18
Looks like you have terminal trouble. Is terminal connected ? Is ROM unlocked ?
When drive comes ready a ST8000AS002 should detect as 8B Lamarr.
If drive goes BSY on reading ID, terminal output typical will give you a hint to continue troubleshooting.
jpkpc3k
Postby jpkpc3k » 28.12.21, 15:08
Thank you for the hint. In the Settings windows on the right hand side I had to enable the additional diag messages.
Code: Select all
FAIL  Servo Op=0100 Resp=0003
So probably dead head.
