WD10TMVW-11ZSMS5 spin down 5 times
CNR
Postby CNR » 22.07.21, 16:02
i got a WD10TMVW-11ZSMS5. transfered ROM (U12) to compatiable SATA PCB (771814 - 771820). there is also a U14 chip on the USB PCB, dont know if that's relevant.
The drive spins up for a few seconds then spins down, it does that 5 times and then stops. no clicks, no noises. i confirmed heads are good by transfering them to a compatiable donor drive and they work great.
Could this be corrupted ROM? and if so what can i do?
northwind
Re: WD10TMVW-11ZSMS5 spin down 5 times
Postby northwind » 23.07.21, 09:06
Did you check if PCB is original?
CNR
Postby CNR » 23.07.21, 10:30
northwind wrote:Did you check if PCB is original?
Thank you for replying,
How do you mean? it's a PCB i took from a different drive that works. the original PCB is USB.
Maxim_TS
Postby Maxim_TS » 23.07.21, 14:30
CNR, try to block SA access in ROM and power the drive. Will it still spin down?
CNR
Postby CNR » 23.07.21, 16:22
Maxim_TS wrote:CNR, try to block SA access in ROM and power the drive. Will it still spin down?
Hey Maxim,
I blocked SA access with this procedure just now: https://blog.acelab.eu.com/pc-3000-for- ... ccess.html
Same spin down 5 times.
northwind
Postby northwind » 26.07.21, 13:03
CNR wrote:Source of the post
I meant if you checked if ROM is original.
CNR
Postby CNR » 26.07.21, 15:58
Oh, the drive was in no other shop before according to the client and I didn't see any signs of tempering on the PCB or drive, so I'm assuming it is original. Is there another way to confirm this?
Postby digitalsupport » 28.07.21, 15:21
Search for WWN from drive label in ROM will confirm if ROM is native
Return to “WD USB”
