WD20SDZW-11JJ8S1 need 6008J F/w
net2
Postby net2 » 15.07.21, 14:26
Hi :wave: ,
Please I need the Loader and DIR with f/w version - 6008J
Thank you :thumbup: .
Doomer
Re: WD20SDZW-11JJ8S1 need 6008J F/w
Postby Doomer » 15.07.21, 18:22
Dirs are pretty much unique on new drives like this
Are you looking for 06.8JD or 06.8JE (these two are not compatible) or something else?
net2
Postby net2 » 15.07.21, 18:37
Doomer wrote:Source of the post Dirs are pretty much unique on new drives like this
Hi Digilab, thank you by your answer,
I need this one:
>ROM version............................. : 06.0JH
>ROM F/W version......................... : 0006008J
>Overlay F/W version..................... : 06.0JH
>Servo F/W version....................... : 03.6B
Do you think is a probability to get it? or maybe I say the customer the drive is not recovery :shockable: . Thank you!
Doomer
Postby Doomer » 16.07.21, 17:32
Here it is
06.0JH.zip
(739.75 KiB) Downloaded 490 times
net2
Postby net2 » 16.07.21, 17:47
Doomer wrote:Source of the post Here it is
Hi, Thank you so much! I will test with this files and let you know!.
Thank you again!!!! :thumbup:
d_d_recovery
Postby d_d_recovery » 16.07.21, 17:55
Thanks for sharing Artem.
net2
Postby net2 » 20.07.21, 15:02
Hi Artem :wave:
I couldn´t use the modules, please help me! can you share the complete modules backup.
Thank you so much by your help, I really appreciate it!.
Doomer
Postby Doomer » 20.07.21, 16:58
net2 wrote:Source of the post
if you need a loader I gave you all the necessary files, just rename them to .rpm files (I thought it's obvious).
net2
Postby net2 » 20.07.21, 17:11
Hi, I have an open case with ACELAB and they wrote me this :roll: :
"Don't know what a files in this archive.
Requiers at least 11, 01 Sa modules, but of course better to get full SA backup." :shockable:
(I renamed with the .rpm and can open your files, but cannot load, or maybe what I am doing wrong?)
Thank you.
Captura de pantalla 2021-07-20 101620.jpg (35.21 KiB) Viewed 14128 times
Doomer
Postby Doomer » 20.07.21, 17:34
you need to rename them as 1.rpm, 10.rpm, 11.rpm
Wow, if these people are tech support I don't know how they can help at all.
Filipp_TS
Postby Filipp_TS » 20.07.21, 18:04
yes, we are tech support but there is no any sences to play charades with something abnormal names and files extensions.
Every one knows file extension of Sa modules = *.rpm
And requested f/w version is 6008J instead of 6000K
net2
Postby net2 » 20.07.21, 18:07
Doomer wrote:Source of the post you need to rename them as 1.rpm, 10.rpm, 11.rpm
Acelab checked the 11.rpm and said that is another firmware:
yours: 6000K
Requires: 6008J
But I want to thank you to take the time to answer the post Doomer :thumbup: , I will continue with the treasure search and as I get it I will upload the files.
Thks!
Doomer
Postby Doomer » 20.07.21, 18:31
Filipp_TS wrote:Source of the post yes, we are tech support but there is no any sences to play charades with something abnormal names and files extensions.
These are the files from ROM version 06.0JH, I have four SA backups of this version and all of them would have 6000K in the overlays (which is how it supposed to be).
There is no SA version in the world that would have 6008J in the overlays, because overlays on Charger drives always have +1 added in the header ie J transforms to K, 8 transforms to 9, E transforms to F etc. So to have "J" in the overlays would require "I" in the ROM revision and it just does not exist on Chargers.
Just don't rely on module 90 information, it is incorrect on Chargers sometimes.
Also, the 6008K overlay header would exist on either 06.8JD or 06.8JE neither on these is present on the WD20SDZW-11JJ8S1 model.
Doomer
Postby Doomer » 21.07.21, 16:24
so no smart comebacks?
and no thank you :) ?
net2
Postby net2 » 21.07.21, 17:13
Hi Artem,
We tried the modules, Acelab also help me to get another one (I attach), but drive looks like the heads was damaged. By the way you were right the 11 shows 6000K, the important for all entering to this post is that we learned another one and now have 6008J files to try in our drives.
Thank you so much by your help and also Acelab Support they always help me! :thumbup:
Andres.
6008J.rar
(690.72 KiB) Downloaded 451 times
