who can check Chip-ID 453E9AB3 in actual Version
goooz
Postby goooz » 07.07.21, 18:32
Hello, can someone check Database of Memory Chips?
Is 453E9AB3 present? If YES please send me a Screenshot of Parameter.
THANKS
Re: who can check Chip-ID 453E9AB3 in actual Version
Postby Roman_TS » 08.07.21, 10:29
Hello. What is the full ID of this chip? You send just the first part. There should be also a second :)
If it's a 7E720000 then it's supported, but I'm seriously doubt that it would be possible to solve this case without latest release with Translator support.
goooz
Postby goooz » 08.07.21, 12:04
Hello Roman,
bad news - had some hope...
The second part is: 7E720D0E
Postby Roman_TS » 08.07.21, 12:26
It's supported, but modern Sandisk cases - are a real nightmare. We can work with them and in most cases we are able to get the best possible result. But the latest software update is required - it contains new Sandisk assembling methods + new XORs for Sandisk cases.
