DE Read from active PC-3000 Utility
davidswa1
Postby davidswa1 » 07.06.21, 21:39
Hello, I've had a few cases where a few of the heads on a drive were giving quite a few errors, but all the heads registered as "good" in the utility and DE. When this happens I'll clear the bad/unreadable sectors and in Parameters use the DE "Read from active PC-3000 Utility, and this works! I don't understand what this function is. Is there anyone who can explain what the "Read from active PC-3000 utility" does and why it works? Thanks much, Dave Sr.
davidswa1
Re: DE Read from active PC-3000 Utility
Postby davidswa1 » 05.07.21, 00:59
I found the answer in the blog.......
Return to “Data Extractor”
