PCB 2060-810035 to SATA Topic is solved
pad-dataservice
Postby pad-dataservice » 20.05.21, 16:54
Anyone got an idea of how to convert this one to SATA?
MasterT
Re: PCB 2060-810035 to SATA  Topic is solved
Postby MasterT » 21.05.21, 12:33
Here you go.
pad-dataservice
Postby pad-dataservice » 24.05.21, 15:30
Thanks - could you give a hit on the two capacitors that are usually removed when converting to SATA :)
MasterT
Postby MasterT » 24.05.21, 18:00
Yes.
pad-dataservice
Postby pad-dataservice » 25.05.21, 12:33
Great thanks :)
osity
Postby osity » 14.09.21, 20:55
Are you soldering a SATA connector to those points on the back, removing 4 capcitors and 1 crystal?
I did that, but my drive is SED.
andrew55
Postby andrew55 » 27.12.21, 11:49
Hello !
Please, tell me which of the points to which contact of the Sata connector leads?
