GIGABYTE SSD bad sector
- thientankt
ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
Thien Tan Data Recovery in Viet Nam
167 Tan Phuoc St 6 Ward, 10 Dist
Tel: (84)907 23 24 62
Skype/yahoo: thientankt
www.cuudulieuhcm.com |www.cuudulieuserver.net | www.phuchoidulieu.net
Re: GIGABYTE SSD bad sector
Hello. Most likely current loader does not fit correctly. Did you try others?
- thientankt
Roman_TS wrote:Source of the post Hello. Most likely current loader does not fit correctly. Did you try others?
I try all Loader but the same result. I receive 6 ssd Gigabyte and all themes same.
Then, current firmware is too new and not completely compatible with existing loaders. Future updates will brings more PS3111 loaders, need to wait.
thientankt wrote:Source of the post ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
Had any chance to try build loader with new PC-3000 SSD Ver. 2.10.2?
- thientankt
otako wrote:Source of the postthientankt wrote:Source of the post ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
New Update SSD Support new firmware phison 3111. You can try
thientankt wrote:New Update SSD Support new firmware phison 3111. You can try
Yup it worked for me. I had a goodram with firmware SBFMP1.3. On older loaders it would not work at all.
Code: Select all
Translator initialization
Creating translator
Read System Info........................ : Ok
Invalid channels count value (0x00)
Parameter "ChannelsCount"=0x01
Invalid chips count value (0x00)
Parameter "ChipsCount"=0x01
Invalid blocks per chip value (0x0000)
Parameter "BlocksPerChip"=0x0100
Invalid pages per block value (0x0000)
Parameter "PagesPerBlock"=0x0100
Invalid page size value (0x0000)
Parameter "PageSize"=0x4000With the loader SBFMP1.4 it worked like charm, no errors while uploading a loader or creating translator.
Code: Select all
System Info:
Chips id................................ : 0x9BC348251000
Vendor.................................. : YMTC
Type.................................... : TLC 16k
Code: Select all
Translator build
Completed
Completed
Test completed
Now I have access to data.
TS with acelab is worth every penny.
otako wrote:Source of the post With the loader SBFMP1.4 it worked like charm, no errors while uploading a loader or creating translator.
Great to hear that solution is working. Actually, the most troublesome thing was the new NAND manufacturer - YMTC. We have never seen it before. Drives with these NAND chips have a different location of SA modules, which makes existing loaders to be useless. Anyway, we added it in a recent update - 6.9.10. Glad that you tried it and got the data!
I confirm, just tried it on the same SSD (Patriot Burst) and it works! Good job!
- dataclinicmx
Hi i tried this one SILICON POWER S55 (PS3111), and worked for me !!
