Old 64 MB CF card not reading properly Topic is solved
Typical Flash recovery cases
Hemendra
Postby Hemendra » 25.02.21, 15:09
As I have found old 64 MB CF card not working so I have chip-off data chip but while reading chip id it is not reading properly as attached image is showing it reads partially.
Data Chip Id - S4044781 SDTNGAHE0-512 126901
Chip is very clean and I have made sure that all lags are fit perfectly still not getting results.
Thanks.
Reading Error.
B20-166 Read problem 8 bit read but not 16 bit.png (94.16 KiB) Viewed 141169 times
Re: Old 64 MB CF card not reading properly
Postby Roman_TS » 26.02.21, 09:19
It's an old memory chip which was not in our database. But we can help you to add it into the software. Please make a ticket, and we will guide you.
Re: Old 64 MB CF card not reading properly  Topic is solved
Postby Roman_TS » 26.02.21, 09:39
UPDATE: chip is in database now :) Please update your resources in PC-3000 Flash and you will be able to read it.
Hemendra
Postby Hemendra » 26.02.21, 12:01
Thanks for the update but after updating resource I still can not read the chip same problem is there. :shockable:
I might think I can not update the resources it is showing repeat download?
d_d_recovery
Postby d_d_recovery » 26.02.21, 17:11
Did you reboot the program after the download?
It does not show unless you do.
I just uploaded the new resources and it does now appear in my database.
https://drive.google.com/file/d/1-bPnit ... sp=sharing
Postby Roman_TS » 26.02.21, 21:51
d_d_recovery is right. Need to restart PC-3000 Flash software after DB update (close all tasks and exit from software)
