Sumsung Head Swap
noushad
Sumsung Head Swap
Postby noushad » 22.01.21, 14:17
Dear all,
patient :-
Model : Samsung ST1000LM024
HDD P/N : HN-M101MBB/AV2
Rev : A
F/W : 2BA30003
DOM : 05/2015
Site : DGT
Donor :-
Rev : A
F/W : 2BA30003
DOM : 01/2015
Site : DGT
will it match ? head swap
Re: Sumsung Head Swap
Postby AJ2008 » 22.01.21, 14:22
I see no reason why it shouldnt.
To be absolutely sure, place patient PCB on donor HDD (or vice versa) - if it spins and motor starts then it will be good. If no motor start then there is some incompatibility between preamps/
northwind
Postby northwind » 23.01.21, 08:54
AJ2008 wrote:Source of the post To be absolutely sure, place patient PCB on donor HDD (or vice versa) - if it spins and motor starts then it will be good. If no motor start then there is some incompatibility between preamps/
This is correct.
Or, just connect terminal on both drives and see preamp version. Patient drive doesn't need to fully spin up and unlatch damaged heads, just power on and off instantly.
noushad
Postby noushad » 25.01.21, 11:07
Thank You
Return to “Spin Point”
