Seagate ST31000524AS stays BSY
elbote83
Postby elbote83 » 22.12.20, 06:46
Hello, the terminal show me:
Bad CRC Seg:0x05
Bad CRC Seg:0x24Bogus ISR
CPSR = 0x200000D2
R14 = 0x00001C6C
stays on BSY state.... Anyone can help me-.... thanks
Re: Seagate ST31000524AS stays BSY
Postby AJ2008 » 08.01.21, 17:28
does it power ok and show solid BSY register?
Filipp_TS
Postby Filipp_TS » 13.01.21, 13:10
Hello, based on terminal report drive has corrupted/damaged/not native ROM.
Read it and compare S/N with S?N on drive's lable - it should be the same.
Postby AJ2008 » 15.01.21, 18:39
If S/N is native like Filipp suggests you check then import adaptives like RAP CAP SAP IAP into similar donor ROM and program to hdd
