Sectors not reading Topic is solved
AYESHA KHAN
Postby AYESHA KHAN » 05.12.20, 17:33
Hi Everyone
I have seagate 1tb Hdd I took full backup and image head1 done head0 image only MFT done for C partition
After that head0 sectors not reading at all even I checked head test it says heads ok
I edit SMP FLAG
AND ALSO I HAVE DONE TRANSLATOR REGENERATE AND AFTER THAT I WORTE 28module back still same not reading sectors i checked head test also again it says heads are ok
Can anyone help me
Thanks and regards
Ayesha khan
Re: Sectors not reading
Postby AJ2008 » 15.01.21, 18:46
Does log show any sense code after sector access attempt? Did you try other steps that you did not write here? Post terminal log after repower, also post result of CTRL+X output
