I'm currently learning the software, and I need to purchase some USB Flash Drives to work on.
Can anyone recommend any Brands/Model numbers of USB Flash Drives that have a working solution in PC-3000 Flash that would be suitable for a beginner to start learning with?
I'm working on a couple of spares that were lying around, but I would like to compare the work I've done so far with samples that have a known working solution (easy beginner case)
All comments and suggestions are welcome!
pd
Sample Drives Topic is solved
- pcdatainsights
Sample Drives
Paul Delaney
k6hr.com
k6hr.com
Re: Sample Drives Topic is solved
Hello! For good cases training I recommend you to buy a - Flash drives with USB 2.0 / 3.0 interfaces with capacity from 4 till 16GB.
After that, write down some photos, wallpapers, office documents on it. Better to fill it by data on 70-95%. More data you will write then more information you get for understanding the future steps.
The best controllers for research are: Phison PS, Alcor AU, Silicon Motion SM, Innostar IS.
Here is the link on a good tool which can show you internal drive controller name and chip ID without flash drive disassembling:
https://www.antspec.com/usbflashinfo/
