St1000LM024 Problem
AdasRip
St1000LM024 Problem
Postby AdasRip » 10.11.20, 19:21
Hello. I also get tired of this model.
After head swap hdd stays in bsy. The drive loops and displays constantly on the terminal:
Code: Select all
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 Found
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 FoundU
S_0SO_1
SPU@20C,5131mV
IS=1
CLA ..36/76
HO..OK
HO RPM=675 OK
AC 1244
ST..Skip..OK
mS1 00000003
GT:399
SC(L):4118/74
BE.N:21
LDUD..OK : 74
PK_3   C:     0 H:0
GT:400
SC(L):4120/63
BE.N:27
LDUD..OK : 63
PK_3   C:     0 H:1
GT:401
SC(L):4124/54
BE.N:26
LDUD..OK : 54
PK_3   C:     0 H:2
GT:402
SC(L):4125/38
BE.N:24
LDUD..OK : 38
PK_3   C:     0 H:3
GT:403
SC(L):4124/16
BE.N:30
LDUD..OK : 16
PK_3   C:     0 H:0
GT:403
SC(L):4120/39
BE.N:26
LDUD..OK : 39
PK_3   C:     0 H:1
GT:404
SC(L):4125/22
BE.N:25
LDUD..OK : 22
PK_3   C:     0 H:2
GT:404
SC(L):4121/38
BE.N:24
LDUD..OK : 38
How to interpret it?
Filipp_TS
Re: St1000LM024 Problem
Postby Filipp_TS » 13.01.21, 13:12
Try to send 'LE' terminal command.
If behavior still the same try to initialize drive with changed Heads map in RAM - set 0000 or 1111.
Return to “Spin Point”
