First Chip FC1179
Typical Flash recovery cases
jerema
First Chip FC1179
Postby jerema » 20.10.20, 15:40
I got an usb drive with chip on board with FC1179 Controller.
Did anyone knows the pinlayout for this controllership ?
goooz
Re: First Chip FC1179
Postby goooz » 20.02.23, 12:53
I need Pinout or Datasheet for FC1178 / FC1179 Controller too. Who can help?
My NAND is complete glued with composite shit.
ACELAB do you have one?
Thanks!
arvika
Postby arvika » 25.02.23, 20:06
This cases are very problematic. Pinout is the smallest problem. It use adaptive XOR + cut pages + software bad bits + problem with structure + complicated assembly algorithm. In fact each cases is other and need special solution. We can solve most of such cases with full structure.
