ST1000LM035 - no ID after ROM swap
AdasRip
Postby AdasRip » 03.09.20, 15:36
I got ST1000LM035 with a burnt PCB.
I changed the ROM and the disk goes to DRD state. However, it does not report an ID.
Does this model have SED?
Terminal show:
Code: Select all
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
FTU
PrgF
(P) SATA Reset
RAW OFF
 PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
MSP213
(MC POR Duration): 000000004F
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
FAFH_TRIGGER_POWER_UP
Re: ST1000LM035 - no ID after ROM swap
Postby AJ2008 » 04.09.20, 10:02
terminal looks ok here - check sata cable. do you see DSC + DRD register? Or you see DWF flag when trying to read ID maybe?
AdasRip
Postby AdasRip » 04.09.20, 20:07
At the beginning I have only DRY and DSC.
After any read operation my drive status is: DRY DWF DSC ERR ABR.
Postby AJ2008 » 08.09.20, 10:07
DWF - Drive Write Fault - device fault state is active and no operation over ATA is possible. This can be patched via patching RAM or SA to give data access. The safest option is patching RAM which can be done through CFW overlay in PC3000
Maxim_TS
Postby Maxim_TS » 22.10.20, 17:50
