WD10JPVX-60JC3T0 - 6 buzz/beeps on power on
DCC-PC3K
Postby DCC-PC3K » 02.07.20, 14:01
Hi All,
I have a WD FBLite 2.5" hard drive (WD10JPVX-60JC3T0) when it is powered on the drive buzzes/beeps 6 times before DRD + DSC is lit, but also ERR and AMN.
Auto detect works and detects the model/family, but defaults to starting in kernel mode and no HDD info is displayed.
Techno mode key
Modules directory address............... : 159 040
ROM Modules:
ROM version............................. : 16.7CG
ROM F/W version......................... : 0016007C
Overlay F/W version..................... : 16.7CG
Servo F/W version....................... : N0.41
I have tried advice from previous questions such as blocking SA access and uploading LDR and firmware of a suitable donor into ram, etc; which gives the XYZ model but no capacity.
Trying to run a heads test after performing this gives "ERR DISK SERVO ACTUATOR AI TIMEOUT". Would the slow drive fix offer any solution, or is there anything else I could try?
Thanks!
d_d_recovery
Re: WD10JPVX-60JC3T0 - 6 buzz/beeps on power on
Postby d_d_recovery » 02.07.20, 18:13
Put your ear to the drive and switch it on. Does it beep without spinning?
What you are seeing is the PCB info, not the actual drive SA.
Maxim_TS
Postby Maxim_TS » 07.07.20, 13:45
Heads may be parked on platters, need to open the drive in clean box and check inside.
