I have WD Hubble 500GB WDC WD5000LMVW-11VEDS3 drive. All essential modules are ok. But 33 plist on head0 is bad in zeros.
1. Can I reduce its size in dir editor?
2. Sectors are not accessible without using utility. I can decrypt and access sectors in utility by using "use utility" option. But in DE task I can only access sectors but its not getting decrypted. What could be the issue?
Data cant be decrypted in DE Task
- murtazabawa
Re: Data cant be decrypted in DE Task
1. you can but P-List is not read by the drive during the boot process and not needed for normal work
2. you drive did not boot properly that's why you cannot read sectors normally
