I got this drive dropped and in inspection found 1 platter is scratched. Also got debris generated from the surface.
Cleaned the surface, tried a donor, it got ready, was able to access few sectors and it died.
First Question - Which one is the H0 in this model? Lower one? or TOP? I believe it's H0
Second Question - In Toshiba - we read CP where Most modules are kept in ROM. Does it matter if surface (under H0) is bad?
Scratched MQ01ABD100
- CS DATA RECOVERY
Re: Scratched MQ01ABD100
hi,
in my practical experience lower one is H0 (MQO1ABD100)...
Regards,
PAVAN KUMAR
CS DATA RECOVERY
PAVAN KUMAR
CS DATA RECOVERY
Ok.
If it would be WD/Seagate we could read from copy 1 in under H1.
But in this toshiba, if we cut h0, can it be read?
