Model - WD40EZRZ-00GXCB0
ROM Ver - 0002001P
Techno mode key
Debug Stop Code reading................. : Status sector reading error Device Error Detected: "VSC ERR VSC CMD SET NOT ENABLED"
SA SPT.................................. : 2800
Read ROM................................ : HDDs ROM reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
Service area:
SA dir reading (ID)..................... : SED DRIVE LOCKED
SA dir reading (ABA/CHS)................ : No S/A regions info avalable
HDD Identification reading ............. : Ok
Allow module 02 access
Module ID 0B reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
WD40EZRZ-00GXCB0 SED DRIVE LOCKED ERROR
- Freakazoid
Re: WD40EZRZ-00GXCB0 SED DRIVE LOCKED ERROR
You need a unlock PCB
POSSIBLE TO UNLOCK USING PC3000? IF NOT WHERE CAN GET UNLOCKED PCB?
PCB NO-800055
