CP33238B (PS3111) support
firdousnet
Postby firdousnet » 05.02.20, 06:17
I have 2 CP33238B (PS3111) cases and one of them with FW:SBFK71W0 while other one SBFK71W1. With FW:SBFK71W1 i have already recovered 60 % of data using Kingston A400 utility connecting directly to sata 0 port. with FW:SBFK71W0 i have tried to connect same way but its creating translator then when accessing the data its going to busy and all sector reading 00 00.Then I follow this instruction ==> https://blog.acelab.eu.com/pc-3000- ... ility.html and connetc through PATA ( utility SmartBuy Revival 2 ) and short safe mode pin and try to upload matching loader but its giving error.The error is below. I have tried this for both drive and same result. I tried to upload different loader also but same error. Anybody have same issue ?
Loader uploading
Code name............................... : Burner_PS3111_71.2.bin
Power Off
Power On
Safe mode............................... : Ok
Write seed.............................. : Ok
HDD Data timeout
Write HDD microcode .................... : Operation aborted
Operation aborted
SSD status:
SSD is in ready state................... : No
Firmware mode........................... : Unknown
SSD is locked........................... : Unknown
Techno mode is locked................... : Unknown
SSD is in Safe Mode..................... : Unknown
Operation aborted
Operation aborted
Re: CP33238B (PS3111) support
Postby Roman_TS » 05.02.20, 07:11
Hello. Please make a ticket in ts.acelab.eu.com and we will help you.
firdousnet
Postby firdousnet » 05.02.20, 07:46
My ticket was #90693
firdousnet
Postby firdousnet » 10.02.20, 06:52
I ordered new PATA SATA adapter and the new error is below. Any chance ?
Selected family......................... : Kingston A400
Controller.............................. : CP33238B (PS3111)
SSD status:
Firmware mode........................... : ROM
Loader uploading
Write PRAM.............................. : Ok
Checking................................ : Ok
Write overlay into PRAM................. : Ok
Write HDD microcode .................... : Ok
SSD status:
Firmware mode........................... : LDR
Read System Info........................ : Ok
Read Chips Info......................... : Ok
System Info:
Chips id................................ : 0x2CB47832AA04
Vendor.................................. : Micron
Type.................................... : 32L(B0KB) TLC 16k
Chip capacity........................... : 52 608 Mb
Channels................................ : 2
Chips (Total)........................... : 0x0C
LUNs per chip........................... : 1
Blocks per chip......................... : 0x0890
Pages per block......................... : 0x600
Sectors per page........................ : 0x20
Size of RAM chip........................ : 32 Mb
Firmware version........................ : SBFM71.2
Build time.............................. : 5 Feb 2018
Interleaved blocks...................... : Type 4
Techno mode lock supported.............. : Yes
Data is packed.......................... : No
Table of blocks pairs reading
Completed
Reassigned block table loading.......... : Ok
Translator initialization
Creating translator
Completed
SSD
Service area scanning
block: 0x0000........................... : 3111 (ISP Id)
block: 0x0001........................... : 3111 (ISP Id)
block: 0x0003........................... : FFD0 (Srv)
block: 0x0004........................... : 3FB1 (Srv)
block: 0x0005........................... : FFA0 (CFG)
block: 0x0008........................... : FFB0 (PrIT)
block: 0x000F........................... : FFC2 (L2P Zone)
block: 0x0015........................... : FFC2 (L2P Zone)
block: 0x003B........................... : FFC2 (L2P Zone)
block: 0x0052........................... : FFC2 (L2P Zone)
block: 0x007B........................... : FFC1 (PrIT)
block: 0x00BA........................... : FFC1 (PrIT)
block: 0x00F9........................... : FFC2 (L2P Zone)
block: 0x0102........................... : FFC2 (L2P Zone)
block: 0x012A........................... : FFC2 (L2P Zone)
block: 0x015E........................... : FFC2 (L2P Zone)
block: 0x0161........................... : FFC2 (L2P Zone)
block: 0x0188........................... : FFC2 (L2P Zone)
block: 0x0190........................... : FFC0 (Smart Vt)
block: 0x01BA........................... : FFC2 (L2P Zone)
block: 0x01DC........................... : FFC2 (L2P Zone)
block: 0x01DF........................... : FFC1 (PrIT)
block: 0x01EA........................... : FFC2 (L2P Zone)
Completed
Service blocks scanning
Completed
Apply filters
Chunks of translator (Found)............ : 0x34550
Filter 0...
Chunks of translator (Deleted).......... : 0x1C6E1
Filter 1...
Chunks of translator (Deleted).......... : 0x107DC
Filter 2...
Used blocks count = 0; TblIndex: 0x0000
Used blocks count = 0; TblIndex: 0x0001
Used blocks count = 0; TblIndex: 0x0002
Used blocks count = 0; TblIndex: 0x0006
Used blocks count = 0; TblIndex: 0x002E
Used blocks count = 0; TblIndex: 0x0038
Used blocks count = 0; TblIndex: 0x0039
Used blocks count = 0; TblIndex: 0x003A
Used blocks count = 0; TblIndex: 0x003B
Used blocks count = 0; TblIndex: 0x003C
Used blocks count = 0; TblIndex: 0x003E
Used blocks count = 0; TblIndex: 0x0042
Used blocks count = 0; TblIndex: 0x0045
Used blocks count = 0; TblIndex: 0x0049
Used blocks count = 0; TblIndex: 0x0056
Used blocks count = 0; TblIndex: 0x0057
Used blocks count = 0; TblIndex: 0x0065
Chunks of translator (Deleted).......... : 0x06D8
Filter 3...
Chunks of translator (Deleted).......... : 0x0000
Filter 4...
Completed
Analysis of obtained data
Estimated SSD capacity.................. : 937 721 856 (0x37E48000) LBA
Available to user....................... : 937 703 088 (0x37E436B0) LBA
User blocks count....................... : 0x06FC9000
Chunks of translator:
SSD..................................... : Used: 0x6FC9; Found: 0x6FBB; Min.: 0x0000; Max.: 0x6FC8
L2P:
Records count........................... : 0x1000
Completed
Translator build
Completed
Completed
Test completed
LBA 0; block: 0x0013; page: 0x40D7; Page marker checking error (Invalid data)
LBA 1; block: 0x0013; page: 0x40D7; Page marker checking error (Invalid data)
LBA 2; block: 0x0013; page: 0x40D7; Page marker checking error (Invalid data)
LBA 3; block: 0x0013; page: 0x40D7; Page marker checking error (Invalid data)
LBA 2 272; block: 0x0013; page: 0x1B80; Page marker checking error (Invalid data)
Soft reset ...
HDD Identification reading ............. : Ok
Postby Roman_TS » 10.02.20, 09:25
Please make a ticker or reply in the old one. We do not provide technical support on forum.
