I consider myself to a newbie in recovery data. I use the PC3000 UDMA.
I got erros on this disk :
Quick test --> data access test --> Read sectors (0-1) error Device error detected "ABR"
SA structure test :
0002 : 0 : B : 164 593 : 3 : Yes : Error : Error : ADDEADDE/DFD9E0DE : : Configuration (HDD ID) (Pasport Sequrity Block)
0002 : 1 : B : 164 593 : 3 : Yes : Error : Error : ADDEADDE/DFD9E0DE : : Configuration (HDD ID) (Pasport Sequrity Block)
002E : 0 : Dr : 6 532 : 308 : Yes : Error : Ok : 58DAC5EE : : Loaded part of microprogram code
002E : 1 : Dr : 6 532 : 308 : Yes : Error : Ok : 58DAC5EE : : Loaded part of microprogram code
CONFIGURATION MODULE (02)
SA Copy num Location State
0 164 593 (3) CS,Header,Header acc
1 164 593 (3) CS,Header,Header acc
I dont know how i can go to further analysis or fix the problem.
Is there anybody who can help me please ?
Thanks in advance.
best regards
WD6400AACS-00G8B1 Erreur
Re: WD6400AACS-00G8B1 Erreur
2E Is Not Important .The 02 Is ,Have You Blocked Mod 02 In Rom To Access SA ?
Hello Amabir,
Thanks for your quick answer.
No i did not block mod 02 to access SA . Do i need to perform it ?
best regards
best regards
lugd.nice wrote:Source of the post Hello Amabir,
best regards
I strongly suggest you read your manual and also all the blogs of WDC ,This will be clear to you ,You are out fishing is the sea without knowing the procedure its very dangerous ,Acelab has a fantastic user manual in WDC
lugd.nice, If module 02 is damaged, it can be restored using the same ROM FW version donor backup.
