Anyone try the HSA from a WD 500GB as a match for a WD 1TB
osity
Postby osity » 11.12.19, 21:43
Any chance the HSA on a WD5000BMVW-11S5XS0 is compatible with a WD10JMVW-11S5XS0 or will there be a density issue ?
I haven't opened them yet to have a look.
Re: Anyone try the HSA from a WD 500GB as a match for a WD 1TB
Postby AJ2008 » 13.12.19, 15:20
Compatibility will not be an issue, head map and head count will be
osity
Postby osity » 16.12.19, 20:19
Both the drive in my possession have 4 heads, so sounds promising.
Postby Amarbir[CDR-Labs] » 29.12.19, 12:48
osity wrote:Source of the post Both the drive in my possession have 4 heads, so sounds promising.
Well,
In That Case It Will Work
Return to “WD USB”
