Anyone had anyluck using the PC3K/DE for NVME SSD drives??
osity
Postby osity » 10.12.19, 16:55
Is it pointless to get a USB adapter and attempt to use DE in any way for recovery of an NVME drive?
d_d_recovery
Re: Anyone had anyluck using the PC3K/DE for NVME SSD drives??
Postby d_d_recovery » 10.12.19, 17:03
I believe Ace are about to launch a new tool aimed exactly at these drives.
osity
Postby osity » 10.12.19, 18:05
I contacted them and they didn't mention anything. A time frame would be great.
Postby digitalsupport » 10.12.19, 18:28
In October Roman teased it as "in future" and November as "You even can't imagine how close this news to our news line"
https://forum.acelab.eu.com/viewtop ... 179&t=9888
LarrySabo
Postby LarrySabo » 10.12.19, 19:38
I've used the DeepSpar USB Stabilizer and a USB NVME adapter to image then recover the data from one. Worked a treat!
d_d_recovery
Postby d_d_recovery » 10.12.19, 19:59
I have the Deepspar PCIe DDI, but have had very mixed success.
Postby digitalsupport » 10.12.19, 20:41
Have used USB to NVMe and PCI-e adapters, modified with DE power control and in circuit power adjustments with mixed success.
But when (not if) memory degrades and errors blocks the drive from init, there is little to do.
osity
Postby osity » 10.12.19, 20:59
Thanks for the responses.
lcoughey
Postby lcoughey » 11.12.19, 13:15
LarrySabo wrote:Source of the post Have used USB to NVMe and PCI-e adapters, modified with DE power control and in circuit power adjustments with mixed success.
I, too, have had some pretty good success with the DeepSpar USB Stabilizer in tandem with DE. Unfortunately, in cases where the translator is toast, there isn't much that can be done with commercially available tools.
LarrySabo
Postby LarrySabo » 11.12.19, 13:54
Not that it matters Luke, but that was @digitalsupport you quoted, not me. :shockable:
Return to “Other SSD”
