wd10tmvw-11zsms1
FDRC
wd10tmvw-11zsms1
Postby FDRC » 10.12.19, 11:27
when i have swap the rom from wd usb 2060-771737-000 to sata board 2060-771692-005 rev 5 not getting power
when i have put back the other rom its working
so what is the problem i have check other pcb of same number 771692
l.pascal
Re: wd10tmvw-11zsms1
Postby l.pascal » 11.12.19, 11:03
It may be that the 2 ROM on different sizes
FDRC
Postby FDRC » 11.12.19, 15:03
can u send the pics for pcb were are 2 rom
FDRC
so that i can swap 2 rom
lcoughey
Postby lcoughey » 11.12.19, 20:09
Maybe you should consider contacting a data recovery pro in your area.
Postby digitalsupport » 12.12.19, 05:48
lcoughey wrote:Source of the post Maybe you should consider contacting a data recovery pro in your area.
+1
FDRC
Postby FDRC » 12.12.19, 10:11
thanks guys i will try to usb soldering its good
Postby digitalsupport » 12.12.19, 12:29
If you have ROM removed, make a backup using external programmer and write it back to SATA pcb via boot ROM.
I prefer to read and write ROM via boot instead of soldering.
FDRC
Postby FDRC » 12.12.19, 19:03
yes i have try its showing rom space is low to write
Return to “WD USB”
