Kingston Phison PS3108
pclab
Postby pclab » 25.11.19, 12:56
Hi Guys
I have this SSD with PS3108.
When I try to create a translator witn FW loader 3.8, I get a message of L2P table missing.
With the other 2 loaders, I only get errors...
Any hints?? Loader not correct?
SSD 8.3.log
(10.24 KiB) Downloaded 444 times
SSD 7.2.log
(35.39 KiB) Downloaded 426 times
SSD 3.8.log
(18.55 KiB) Downloaded 428 times
Re: Kingston Phison PS3108
Postby Roman_TS » 26.11.19, 06:48
Loader is correct, the problem is in damaged or erased L2P tables which includes information for translator rebuilding. Most likely drive is seriously damaged in FW part. Without L2P recovery will be not possible.
otako
Postby otako » 13.05.21, 15:37
I know it's an old one, but had same "L2P table missing" issue with loader Burner_PS3108_8.3.bin or 3.8.bin
Did google it and that's how I end up here ;).
SSD drive I had is Silicon Power S60 with PS3108.
It worked fine with Burner_PS3108_7.2.bin, so maybe it's worth checking other loaders before giving up.
ssd.log
(18.51 KiB) Downloaded 356 times
HEX
Postby HEX » 12.11.23, 09:24
We have exactly the same problem.
Intenso SSD on the PS3108 controller with 98DEA48276D6 memory.
No L2P tables can be found on any Loader, generally the logs look the same as those posted by PCLAB.
In our opinion, this looks like incompatible software.
- Lukas -
