I've got a case here that's really bringing out a glitch in the Flash program. I've created the task four times, even have tried totally re-installing the software, and it keeps happening with this case. I was able to do the find ECC once working directly from the NAND, but after I get the dump (which seems to go well every time) when I do the "ECC Autodetection" it just does nothing, absolutely nothing. No errors in the log, just does nothing.
Anyone else have this glitch? Was it resolved in a later update (I'm currently capped at version 7.2.9.4131)
Program Glitch, ECC Autodetection Does Nothing
Re: Program Glitch, ECC Autodetection Does Nothing
ECC correction was done on dump or on Transformation Graph ?
DataMedics wrote:Source of the post I've got a case here that's really bringing out a glitch in the Flash program. I've created the task four times, even have tried totally re-installing the software, and it keeps happening with this case. I was able to do the find ECC once working directly from the NAND, but after I get the dump (which seems to go well every time) when I do the "ECC Autodetection" it just does nothing, absolutely nothing. No errors in the log, just does nothing.
Please contact TS and we will help you.
We do not provide Technical Support on ACELab Forum.
Multi-COM wrote:Source of the post ECC correction was done on dump or on Transformation Graph ?
It doesn't matter where I try to do it, nothing happens. It started to work once after I did a fresh reinstall of the program, but I had to stop it for some reason, and the glitch came back.
DataMedics wrote:Source of the post It doesn't matter where I try to do it, nothing happens. It started to work once after I did a fresh reinstall of the program, but I had to stop it for some reason, and the glitch came back.
If you really want to solve your problem, but not just complain about it - better to leave a ticket
