I have Seagate rosewood , 2tb , St2000Lm007 Hard Drive.
1. While applying patch from pc3000, version 6.6.36. It gives error it is already patched.
"ROM is already corrected!
Tech Mode unlocking preparation, (patch).................... : Error
Error correction ROM data"
2. While deleting patch from utility. gives following error.
Error : BFW compatibility sect. inx err!
"Tech Mode Unlock (patch)" delete........................... : Error
I can not access the Terminal. Shows diagnostic port is locked. I have attached the patch rom file.
The HDD detects perfectly. I can access few sectors from starting. It has media cache problem.
Terminal Out put
Boot0x80M
TCC:0021
QB
Rst0x80M
T:0x000C 0x3162FB2C
FTU
TCC:0021:0028 EMCDataErr:00000012
PrgF
(P)SATAReset
RAWOFF
PASS
EDACValue=00000000FFFFF111
SIMFileFD=FC3B3348ErrorCode=44090082DiscLBA=0000000000006498Duration=00000821ms
SIMFileFD=FC3B3348ErrorCode=44090082DiscLBA=0000000000013E98Duration=00000821ms
MCMT table is corrupted
6GbMaxSpeedloweredto3GbforIntelbug
SendStatus:COMRESETseen
CSpd=3Gbps
FIS34
DOS:0 Scan Unit
How to get terminal access?
Thanks,
Rosewood EB01 Error : BFW compatibility sect. inx err!
- Attachments
- ROM.rar
- (279.16 KiB) Downloaded 541 times
Re: Rosewood EB01 Error : BFW compatibility sect. inx err!
on pc3000 imposible yet make it what family you see
Hemendra, Hello!
It's should be possible to solve. Please create a request for our TS and we will help you.
we make today one it need unlocked rom but not on pc3000
tronkass wrote:Source of the post we make today one it need unlocked rom but not on pc3000
I have attache the rom file. Can you modify this rom and solve it?
Hemendra wrote:Source of the post have attache the rom file. Can you modify this rom and solve it?
You can do it with PC-3000. Just make official ticket request and our guys will help you
Thansks to ACELab team. Created ticket and resolve the problem.
how did they solve it?
elbote83 wrote:Source of the post how did they solve it?
The only way to know that - make a new ticket in our TS system
