I am not a usual user of Data Extractor for logical recovery...
It has done a partition scan and found a valid NTFS partition on the faulty disk and has shown a folder tree on right-hand-side panel.
But, the last time I used DE, there was little check boxes beside each folder. I could then select folders and use a "copy" command.
However, this time I can see no check boxes beside recovered folders and no option to "copy" these files?
Where is the option to copy files off Data Extractor?
- d_d_recovery
- User
Re: Where is the option to copy files off Data Extractor?
You need to go back into the main window, open up 'Disk Folder Result' and your check boxes will be there.
