Toshiba 3.5 DT01ACA200 - Busy state
RCCU-Brussels
Postby RCCU-Brussels » 03.10.19, 15:14
We tried to access to the datas of a Toshiba DT01ACA200. The state is always "Busy" and it's clicking.
We noticed that the heads left the "Park zone" to the center non stop, the surface area don't seem accessible.
Here is a capture of the voltage
We removed the PCB from the hard drive and we choosed the profile "7210DLE6" (we saw on Internet that this profile correspond to a Toshiba DT01ACA200) and we have this error :
Code: Select all
Selected family......................... : 7210DLE6
PCB only start!
Error reading module USAG(0): PCB only start!
PCB only start!
Error reading module USAG(1): PCB only start!
Error : .............................................................. : Module USAG: no copies read!
Error : .............................................................. : PCB only start!
We also tried the profile "MG03ACA" from Toshiba but we have this error :
Code: Select all
Techno On............................... : Device Error Detected 51/04 (ABR)
Zone table.............................. : Zone table read error; Device Error Detected 51/04 (ABR)
G-List reading error.................... : G-List read error; Device Error Detected 51/04 (ABR)
CP Avalable............................. : 49
We have a donor hard drive but we think it's a logical problem
EDIT:
We also follow the steps from this article https://blog.acelab.eu.com/2045.html :
What about drives which are get a BSY state without Drive ID and capacity?
Maybe problem called by damaging G-list or SMART.
Try to perform the next steps for Service Area access:
1. Turn off the power supply and isolate Heads contacts on PCB.
2. Turn on the power supply. Now disk BUSY.
3. Perform Soft reset (F7), if it doesn’t help then perform Hard reset (F8).
4. Now drive get a ready state. Then perform Sleep (Standby) comamnd. Go to “Tools” -> “HDD” -> “Standby”
=> We have always a busy state with the isolation of heads contacts
Sergey_TS
Re: Toshiba 3.5 DT01ACA200 - Busy state
Postby Sergey_TS » 17.12.19, 12:58
RCCU-Brussels, regarding your description it's not a logical problem. I'm more than sure it's a heads failure.
Actually this drive isn't a Toshiba so all actions you did from the article for diagnowstic won't work here.
Good luck with heads swap! :wink:
Users browsing this forum: Google [Bot] and 1 guest
