Solution for 512 MB - LC98800BQ Controller - K9G4G08U0M
Bio
Postby Bio » 02.10.19, 16:45
This is my first post here on forum so im sorry if i do something worng. I'm a beginner
I have Recorder to recover data. Can someone please help me with solution to get data?
Controller: LC98800BQ
Number of memory chip: 1
Number of parts: 1
Memory chip marking: K9G4G08U0M
Memory chip ID: 0xECDC1425
Capacity: 512 MB
Chip is reading with no errors. But i dont find any solution at Global Solution Center
Thank you for help. Have a nice day.
d_d_recovery
Re: Solution for 512 MB - LC98800BQ Controller - K9G4G08U0M
Postby d_d_recovery » 02.10.19, 17:29
Can you send a picture of the recorder and the chip?
Is it an Olympus?
Postby Roman_TS » 03.10.19, 08:04
Hello. If you need a help with case recovery, please send us a ticket in Technical Support portal. We do not provide TS in forum.
https://ts.acelab.eu.com/index.php?/Tickets/Submit
Bio
Postby Bio » 03.10.19, 18:25
d_d_recovery
Thank you for your answer. Yes it's Olympus VN-5500
https://zapodaj.net/281a3338fc909.jpg.html
https://zapodaj.net/ce3a845ba0105.jpg.html
d_d_recovery
Postby d_d_recovery » 03.10.19, 19:32
I would take up Romans offer of support on this one as the controller is not supported. However even if you do mange to get a dump data you may not be able to decode the recordings. For years Olympus have been using proprietary codecs. Getting one of these recordings to play outside the original environment will be extremely difficult. I had a similar issue a while ago with a similar recorder and this is what Olympus said.
Unfortunately, it is not possible to playback this type of file out side the recorder, as this uses a proprietary audio codex only available for playback in this type or recorder. We have gotten this type of request in the past, however, Olympus Tokyo has made it quite clear that this is not possible, as there is no application or software available for the PC that can covert or playback these files. The only possible way to playback these files would be to buy another working VN-7200 recorder, and duplicate or transfer the files from one memory chip to the working chip on the good recorder. After that is achieved, the files can then be playback and copied over using another recorder or audio recording software, and the earphone out jack.
Bio
Postby Bio » 04.10.19, 07:38
Roman_TS and d_d_recovery thank you for your answer. I wrote a message to TS and also i'll search other working device.
