ST31500341AS cliking, I can't read system files from the terminal
Jaime
Postby Jaime » 20.09.19, 10:08
Hello friends
I have a new issue.
I received a hard drive didn't spin, I opened the hard disk in clean room and the hard disk had the motor gripped and the heads damaged.
I swapped the platterns to other disk compatible and installed donor's heads.
Now when I attatch the hard disk to PC3K
The terminal shows
Rst 0x20M
The hard drive starts cliking noise, but it doesn't stop spin the motor.
I try to read the system files by the terminal I can't do it, but
if I run Control-R, in ATA (indirect) mode.
Disable flag smp
I can read the modules and system files of service area,
less the module 1B, I can't read it with head 0 and 1, it gives a error
I checked the terminal and it isn't locked.
When I do the heads test /7 X , it is good.
Anyone have any ideas.
Thank and regards.
Jaime
I attach the terminal log
HDD family detecting...
Family ID: 2D
Selected family......................... : 2D, Brinks
Model by ID............................. : ST31500341AS
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ BR448B.CCD1.CG120H.
Detecting SA Phys Sct Size...
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 8
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
ID Len
0 4 Reserved Defect Table (SA defect table)
3 3787 Primary Defect File (P-List)
4 12 Servo Adaptive Parameter File (SAP)
8 4800
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
26 80 Drive Self Test (DST), Head 4
27 80 Drive Self Test (DST), Head 5
28 80 Drive Self Test (DST), Head 6
29 80 Drive Self Test (DST), Head 7
2B 1172 R/W Operating Parameters (translator, etc)
2F 432 Data Integrity Check (DIC), HEAD 4
30 432 Data Integrity Check (DIC), HEAD 5
31 432 Data Integrity Check (DIC), HEAD 6
32 432 Data Integrity Check (DIC), HEAD 7
33 4576
35 26 SMART Data
3A 4
Collecting DT Infos...
ID MemOffs Len
0 6020100 33792 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4001000 4096 Servo Adaptive Parameter File (SAP)
602BE00 4096
total 8192
A 60A6E48 1024 Seek Profile
13 60B1ED8 544 Dependent Zone Table for User Area
14 60B20F8 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60B1200 3288 Dependent Zone Group Tables for User Area
1C 60B10C0 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020310 2320 Zone Format Parameters File
ID MemOffs Len
2 60201F0 288 Zone Table
602BE00 4096
total 8192
6 267C44 40996 Servo Flaw Table
16 6020100 32 Drive Configuration Table
17 6021F20 1744 Temperature Control Configuration
1F 6184690 1224 RW working user preamp table
20 6184B58 72 RW working system preamp table
Collecting DT Infos completed
System Files I/O method detection... ATA(indirect)
Buff Root FAT searching in RAM......... Ok
Searching CFW OVL FID in RAM............ Ok
