PC3000 Constant Beep ?
Cire3
Postby Cire3 » 18.09.19, 16:57
I have had a few source drives make PC3000 beep from time to time. However I have 2 X Toshibas that are making PC3000 card beep constant. As soon as I start copying to target disk it starts until finished.
Is this an error I should be concerned about ? It's annoying at best... Again this is PC3000 making the long constant beep, not the hard drives.
Thanks in advance !
PC3000 Express
Oh dam, it actually ran for a while then popped out this error : Access violation at address 4006D736 in module 'Vcl50.bpl'. Read of address 16039EC3
Access violation at address 4006D736 in module 'Vcl50.bpl' Read of address Error
PC3000 memory Error.PNG (14.35 KiB) Viewed 10941 times
Re: PC3000 Constant Beep ?
Postby DataMedics » 18.09.19, 21:02
I sometimes get these random errors. Usually just closing the PC-3000 software and reopening it solves the issue.
Cire3
Postby Cire3 » 29.06.26, 17:47
I have had this happen if power is lost to the card "SATA power" Had a loose connector , and the card itself beeped.
italyassistance
Postby italyassistance » 04.07.26, 10:04
the beep appear with there are electric problem, check pcb or sata attach
