WARNING! SET FEATURES subcommand required to spin-up after power-up!
Selected family......................... : 7250A7
Model by ID............................. : HGST HTS725050A7E635 OPAL
Techno mode key......................... : Error
ROM reading...
Possible Tech Key is found. Checking...
Error executing command: Reading SA [0x3F0000004, 0x4]
Device error detected "ABR"
Error reading module USAG(0): Error executing command: Reading SA [0x3F0000004, 0x1]
Error executing command: Reading SA [0x3F0100004, 0x4]
Error reading module USAG(1): Error executing command: Reading SA [0x3F0100004, 0x1]
Error : .............................................................. : Module USAG: no copies read!
Error : .............................................................. : Error executing loading "open" modules dir command
Dear Frds
The above error is coming while accessing hdd ,No head noise in the hdd kindly advise me in this problem
HGST HTS725050A7E635 OPAL ( 0 MB )
Re: HGST HTS725050A7E635 OPAL ( 0 MB )
Probably bad heads. If not that, then it's a corrupted modules table, which is even worse.
DataMedics wrote:Probably bad heads. If not that, then it's a corrupted modules table, which is even worse.
how could i fix corrupted modules table ?
