ST500DM002 FW:KC48
nasseri54
ST500DM002 FW:KC48
Postby nasseri54 » 15.08.19, 12:30
Hi to all
i have a HDD 500 barcuda ST500DM002 FW:KC48
During power ON, it stays BSY and i see this in Terminal:
Boot 0x10M
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
And The terminal doesn't work,
Then I tried shorting and it became READY and the motor also keeps running, with the following details and terminal output:
Model : ST_M13FQBL
Serial : QNR_BFW
Firmware : 02131127
Capacity : 3.86 GB (8 089 950)
Boot 0x10M
Spin Up[0x00000000][0x00000000]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
FAIL Servo Op=0155 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x00025CB4][0x00025CB4]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
FAIL Servo Op=0055 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x0000B319][0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x00030FCD][0x00030FCD]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWYWWMMMMMM
If I turn off power and again power On it, it again stays BSY and have to repeat the same procedure to get it READY.
What is the problem? what should i do now ??
best regards.
Re: ST500DM002 FW:KC48
Postby digitalsupport » 15.08.19, 19:30
nasseri54 wrote:Source of the post FAIL Servo Op=0155 Resp=0007
The drive has bad heads. Open the drive in clean room, check heads under microscope, clean or replace heads.
nasseri54
Postby nasseri54 » 17.08.19, 11:31
digitalsupport wrote:Source of the post
This model has 2 heads and I checked, the heads are healthy.
Postby digitalsupport » 18.08.19, 09:34
But "FAIL Servo Op=0155 Resp=0007" says something else, try with a new set.
nasseri54
Postby nasseri54 » 18.08.19, 14:51
I also tested with new heads, But the result was the same.
Postby digitalsupport » 18.08.19, 17:00
And original heads work in donor ?
GuideRecovery
Postby GuideRecovery » 19.08.19, 10:17
digitalsupport wrote:Source of the post Boot 0x10M
you are shorting at wrong time, try shorting after 2nd Rst 0x10m msg... it should get you the terminal
Wasim Zafar
https://mindmergepk.com
