Hello All,
I Have a Rosewood With Partial Access Due To Tempering From Older DR Guys ,No Backup Of SA And SYS Files ,This is What i Get When i Issue Command To Regenerate Translator
Max Wr Retries = 08, Max Rd Retries = 32, Max Iterations = FF, Max Certify Rewrite Retries = 29D1
Ev LBA/Soft XferLen Zn Trk Hd Sct Wdg PBA ErrCode
(DOS) File Save Pass Wrst Ct: 0000 SU: FFFFFFFF NT: 00000000 OT: 00000000
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
MCMainPOR: Start:
Media Cache Data Base 00E8EB20D8
MCInitialize: Start: Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes): Starting LBA 00E8EB20D8, Count 01CF8718
TCC:0023:0033..
ClearMC: Completed, Last LBA 00EABAA7F0
MCInitialize: MC Cleared
MCInitialize: MCMTBufferPtr->Header.MCMTHeader.MediaCacheDiscStateFlags = 0000000A
MCInitialize: MCMTBufferPtr->Header.MCMTHeader.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
MCMT Save:Pass
MCInitialize: Init complete:
MCMainPOR: MediaCacheDiscStateFlags 00000022 MCStateFlags 00000040
(MC POR Duration): 000001B1F8
Zero out MBR and DataStore: Writing LBAs 0000E8E088B0 to 0000E8EB20D7
LS PFS= 2000v{0008}qv{0008}qv{0008}qv{0008}qZero out MBR and DataStore: Fail
DiagError 00005004
User Partition Format Failed - Elapsed Time 0 mins 30 secs
R/W Sense 00000001, R/W Error 00000080, File Error 00000000
LBA 000000000000, Cyl 00004830 Hd 00, Phy Sec 000, Wedge 0024
PS : What is The Cause Of This Error " Weak/BAD Heads ? , Whats DiagError 000050004 ?
Translator Regeneration Fails - Rosewood
Re: Translator Regeneration Fails - Rosewood
I believe it means that the drive failed to write.
But why are you trying to regen translator???
northwind wrote:Source of the post I believe it means that the drive failed to write.
Well,
Drive Has Come From Pakistan , It Was Given To Some Local There And He Might Have Tried All Type Of 2nd And 3rd Grade Stunts On It , Then The Drive Was With Our Friend Wasim " He Was Busy EeeD Time " And Told The customer About The Translator Issue And No Original Backups , So It Crossed Borders And I Am Working On This Now ,I Will Hopefully Change Heads And Try As Much Translator AS i Can Built , Any Suggestions ,Could it Be BAD SA Surface Too ,I am able to read write sys files .
