I have Toshiba 256GB M2 Toshiba SSD kbg30zmv256g.
The hdd is not detected. Behavior like NO hdd is connected with pc3k or like the power failure hdd.
I have tried to found faulty components and created the output voltage diagram.
Attached the image of m2 sata. How to recover the data?
Thanks,
Power Failure M2 Sata Toshiba SSD kbg30zmv256g
Re: Power Failure M2 Sata Toshiba SSD kbg30zmv256g
This is NVMe. You need to connect it to motherboard.
