Samsung ST2000LM003 Not ready
gpgeorge
Postby gpgeorge » 18.05.19, 10:10
Model - ST2000LM003
P/NO - HN-M201RAD/AV2
FW - 2BE10001
Problem Not ready (Good spin)
gpgeorge
Re: Samsung ST2000LM003 Not ready
Postby gpgeorge » 18.05.19, 11:51
Test Log
ActiveFW : 00
FWVer : 0001DDR detected:16MB
*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002
*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002U
S_0
PCBA I/O Voltage : 1.8V
PREAMP : 1.8V
FLASH : 8Mbit
KonaRev: TI 4.3
Kona FSYS divider: 1
VCore1 RCS Disable
VN on
VN off
SO_1
Set Target RPM = 5409(0000906Fh)
IS Max= 400 (001Dh)
SU Max= 450 (0020h)
DefaultKval : 711 TargetKval : 2759
RPL......Done:1
RPA......Done:36/92
HO..Done @RPM= 566
RU.....................................................Done @RPM= 5402
ST..Skip
SUT= 2417
mS1 00000002
VDAC Offs K0 ............Done: -93
VN on
SHK on
VBEMF Offs .....Done
VBEMF Gain ....Done
A1O= 2 A2O= 1 SWO= 57
A1G= 1381 A2G= 7 SWG= 62
Rvcm= 11310 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..OK
DSA on
SK C: 8881 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1C
MasterT
Postby MasterT » 18.05.19, 15:24
If no strange sounds you can wait longer to get ready.
It only loaded these 2 modules so far:
If it ends with LED1A04 error in terminal than you should send LE command to gain access.
Otherwise it can be weak heads or media damage.
Check under the microscope to see if there are any scratches in the SA area on the platter:
https://www.datalab247.com/articles/drive-firmware.jpg
If there are no visible scratches under miscroscope than heads are week you should look for the one with this preamp: *PAUNI_L2958*PA VID=0011 PN=000E Rev=0002 to swap.
Good luck.
Return to “Data Extractor”
