Toshiba USB Compatible SATA HDD
odedshankar
Postby odedshankar » 09.05.19, 07:57
Hi Guys,
I got the following USB Toshiba 2.5" drive:
MQ04UBF100
AZA AB21/JU002U
DATE: 28SEP2018 so relatively new drive.
USB PCB Number: G0034A
Does anybody know what is the compatible SATA drive or SATA PCB version?
shahi
Re: Toshiba USB Compatible SATA HDD
Postby shahi » 10.05.19, 22:20
MQ04ABF100 is compatible.
odedshankar
Postby odedshankar » 12.05.19, 00:37
thanks shai.
Postby DataMedics » 13.05.19, 17:53
It's not exactly rocket science here. Just replace the "U" in the model number with an "A" and it's the SATA version of the same drive.
odedshankar
Postby odedshankar » 14.05.19, 00:32
i know that mate, that's what i usually do with Toshiba drives, but always prefer to validate it with someone that already tried it for a specific drive to save cost on donor drives. Better to be on the safe side of things.
net2
Postby net2 » 15.01.20, 00:11
Hi, I used a PCB with the A but didnt work, maybe is something with the PCB Number?
Customer drive>
MQ04UBF100
AB21/JU002U
31 JUL 2018
PCB NUM: G0034A
DONNOR drive:
MQ04ABF100
AA00/JU000A
3 Nov 2019
PCB NUM: G4311A
Please, what I am doing wrong?, Now I just receive Toshiba USB drives.
Thank you.
odedshankar
Postby odedshankar » 15.01.20, 02:08
Hi there,
can be few issues, like FW corruption and faulty heads which are the actual problems with the drive.
Cheers
northwind
Postby northwind » 15.01.20, 09:44
For G0034A you should use G4311A, so your conversion is correct. If it 'doesn't work (that could mean a million things, does it not spin up? does it spin up but doesn't ID? etc), then something else is the problem.
Postby DataMedics » 20.01.20, 21:39
Perhaps an obvious question to more experienced guys, but given that it's your first post I've got to ask..... did you transfer the ROM chip from patient to donor?
Filipp_TS
Postby Filipp_TS » 18.12.23, 10:24
G0089A -> G4311A
Filipp_TS
Postby Filipp_TS » 03.06.24, 09:32
Confirmed:
G0090A -> G4311A
Dougstvdata
Postby Dougstvdata » 01.03.25, 00:23
I am a little confused. I have a Toshiba MQ01UBD100 with board G003250A. Every post I find says that board G003138A is the Sata equivilant but on original board there is a IC602 that everyone keeps saying is the ROM chip to swap, but my IC602 is a ST.
IC602 Original Board
2SP40VG
HPAHQ V(and what looks like a backwards Z beside the V)
KOR 4240
ST
IC606 Original Board
25X20BL
1502 03
642B
5Z100
There is a Winbond ic at location IC606 also, and what I have found out it is also a Bios Rom chip. The G003138A that I keep seeing is sata equivilant does not have a IC606 location and the in location IC602 is a Winbond iC and looks to be a 25X40BL
Do I swap the ST ic in location IC602 (original board) with the Winbond ic in location IC602 (in donor board) and not worry about the IC606? Or do I swap the Winbond IC's around?
Or is there a way to solder a SATA connection onto the board like the WD drives? I seen some post of people doing it but cannot find where exactly to solder the A+/A-/B+/B- and 5v lines and if I have to take out the same type of capacitors from the USB line like on the WD drives.
I have been working on electronics for 21 years but I am new to the data recovery scene. Any help would be greatly appreciated.
ads
Postby ads » 04.07.25, 15:18
hi toshiba pcb no -G0090A compatible pcb G4311A
what needs to be changed
Return to “Toshiba native”
