not detect
sepid
not detect
Postby sepid » 30.04.19, 07:15
hi to all
i have a hdd wd10ezrx-00l4hb0
when power on, For the duration 2m bsy after 2min led bsy off and only led error on
then auto detect :
Techno mode key
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
Modules directory address............... : 208 640
SA Translator loading................... : Module ID 30 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
ROM Modules:
ROM version............................. : 01.26G
ROM F/W version......................... : 00010026
Overlay F/W version..................... : 01.26G
Servo F/W version....................... : 12.22
Head Map Reading Error.................. : Head map check sum error
i do upload ldr
all module is ok and test head too is ok
thanks
AdasRip
Re: not detect
Postby AdasRip » 03.05.19, 23:50
This disk has only one head? Damaged map of heads?
sepid
Re: not detect
Postby sepid » 04.05.19, 15:19
yes
head map is damage
now only 1 head
but i think this hdd have 4 head
Maxim_TS
Re: not detect
Postby Maxim_TS » 08.05.19, 21:36
sepid, block SA access in ROM and restart the drive. Will the head map be the sme and module 30 with error?
sepid
Re: not detect
Postby sepid » 09.05.19, 14:33
hi
i do SA black
and upload loader is ok
test head is ok
all module ok
but when Allow SA access agin hdd bsy
i do in rom module 20b change
at line 0x0020 02 01 00 18 00 03 18 90 02 00 2F 03 00 00 2F 03
i did change 0x0020 02 01 00 18 00 03 18 90 02 00 2F 02 00 00 2F 02
hdd out of bsy and led on DRD DSC
but do not upload loader
Module (0001) read error Module ID 01 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Maxim_TS
Re: not detect
Postby Maxim_TS » 09.05.19, 16:55
sepid, return the original modules back including 20b, and solve Slow Responding in drive. Then allow SA access in ROM and repower the HDD.
sepid
Re: not detect
Postby sepid » 11.05.19, 14:16
thanks maxim
i did before slow Slow Responding but no ansewer
when i do upload loader and Ram head map edit hdd detect ok and all head is ok
but when i press " allow SA access and restart " hdd no detect
