PALMAR SLOW FIX
shahi
PALMAR SLOW FIX
Postby shahi » 23.04.19, 19:01
Anyone worked with SLOW FIx issue in PalMar?
I've tried manual process, but drive ID is lost once tried.
PS # I've backed up all the fw before doing anything in SA
lcoughey
Re: PALMAR SLOW FIX
Postby lcoughey » 24.04.19, 14:07
I didn't think Palmer with SMR was supported with PC3000.
shahi
Re: PALMAR SLOW FIX
Postby shahi » 24.04.19, 17:27
lcoughey wrote:Source of the post I didn't think Palmer with SMR was supported with PC3000.
Once we use unlocked PCB, we can access fw.
lcoughey
Re: PALMAR SLOW FIX
Postby lcoughey » 24.04.19, 17:35
shahi wrote:Source of the post
But, there still isn't a palmer utility, is there? To the best of my knowledge, none of the utilities are equipped to handle SMR SA and any attempt to write to SA could lead to the death of the drive.
Re: PALMAR SLOW FIX
Postby AJ2008 » 25.04.19, 11:03
Also, its not possible to recal CS on Palmer within PC3K to confirm changes - writing a 'empty' 32 module from a donor may help but this wont disable the relo collection process within module 02
I hear Palmer has support in the next release of PC3000 (and within current beta release) but I dont have it so I cant confirm...
shahi
Re: PALMAR SLOW FIX
Postby shahi » 25.04.19, 18:25
No, there is no palmar utility, but we can access by pebbleb.
AJ2008 wrote:Source of the post Also, its not possible to recal CS on Palmer within PC3K to confirm changes - writing a 'empty' 32 module from a donor may help but this wont disable the relo collection process within module 02
I tried to edit manually the soecifuc area, but drive lost ID once did it. Rewrite originsl 02 gave access again.
Really? Its a good news about the new release. When is it coming? Any estimated date?
lcoughey
Re: PALMAR SLOW FIX
Postby lcoughey » 25.04.19, 18:38
shahi wrote:No, there is no palmar utility, but we can access by pebbleb.
I don't believe pebbleb is equipped to handle SMR.
Re: PALMAR SLOW FIX
Postby digitalsupport » 27.04.19, 14:22
There is a palmer utility now :D
shahi
Re: PALMAR SLOW FIX
Postby shahi » 27.04.19, 15:57
Yes...
I'm going to renew my TS, hopefully it gets working in my case...
Bruno
Re: PALMAR SLOW FIX
Postby Bruno » 06.05.19, 14:34
anyone worked with the pc3k 6.6.29 and fix slowresponding Problem on an WD Palmer without buy unlocked PCB?
pclab
Re: PALMAR SLOW FIX
Postby pclab » 06.05.19, 17:21
I don't think it's possible..
Bruno
Re: PALMAR SLOW FIX
Postby Bruno » 07.05.19, 12:57
Thank for the reply. I think also. So yesterday we ordered a unlocked PCB.
shahi
Re: PALMAR SLOW FIX
Postby shahi » 07.05.19, 20:30
The unlocked PCB helps but the version still doesnt help slow fix. Since it requires more work in palmar
Maxim_TS
Re: PALMAR SLOW FIX
Postby Maxim_TS » 08.05.19, 20:45
shahi, Indeed, Slow Responding Fix is not recommended to apply for SpyGlass and Palmer drives because of new 02 module structure.
ACELab developers are working on it.
But, the new version allows to get SA access, edit head map in RAM, build head map in DE, it's a very useful features, isn't it?
lasek
Re: PALMAR SLOW FIX
Postby lasek » 09.05.19, 11:29
But to get access to SA needed is unlocked PCB also with the last version PC-3000?
