FBLite 2.5" Module ID 20B FM ERR CHECKSUM
RDDmx
Postby RDDmx » 29.03.19, 01:10
Hi to all,
I have WD WD10JPCX (fblITE 2.5"). The disk sounds normal (no clics, no grinding, no stops), PC3k with the terminal (nirmal mode) shows the following message:
Techno mode key
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Read ROM................................ : Module ID 20B reading error Data request error Device Error Detected: "FM ERR CHECKSUM"
Service area:
SA dir reading (ID)..................... : Drive is not ready
SA dir reading (ABA/CHS)................ : Dir reading error ABA 0(1) reading error Device Error Detected: "VSC ERR UNSUP ACTION CODE"
Configuration reading................... : Module ID 02 reading error Data request error Device Error Detected: "Unknown error code: 3746"
Can anybody point me in the right direction? I think I can get the modules from another source but what bothers me is the "Unknown error code: 3746" and I don't know the correct order of the operations I need to do.
Thank you in advance. Please be kind :D
Maxim_TS
Re: FBLite 2.5" Module ID 20B FM ERR CHECKSUM
Postby Maxim_TS » 01.04.19, 16:06
SA SPT Detect........................... : FAIL may be if heads can't see platters.
Also, FBLite drives can spin even if heads are bad.
In my opinion, it's head issue. But I also would like to see what another forum members would say :)
d_d_recovery
Postby d_d_recovery » 01.04.19, 17:31
This is a pretty comprehensive article on how to handle most WD Marvell drives. Just be aware that if the heads are failed, you might be causing damage to the platters, so best take a look under the hood first.
https://blog.acelab.eu.com/pc-3000- ... stics.html
