critical case,please help
Typical Flash recovery cases
ankarakecis
Postby ankarakecis » 12.03.19, 07:33
hi, we have flash chip. we try solution from pc3k solbase. But there is different between solution map and chip map. why is the different?
chip map-invalid.PNG (43.01 KiB) Viewed 10872 times
solution map-invalid.PNG (11.09 KiB) Viewed 10872 times
Re: critical case,please help
Postby Roman_TS » 13.03.19, 11:27
Hello. If you need help with case recovery, you should create a new ticket here:
https://ts.acelab.eu.com/index.php?/Tickets/Submit
